Super A Crankshaft pulley
Paul H
09-18-2006 14:50:49
Does anyone have any suggestions on getting a stubborn crankshaft pulley off?
many thanks Paul
Keith-OR
09-19-2006 21:19:30
 Re: Super A Crankshaft pulley in reply to Paul H, 09-18-2006 14:50:49
Paul. here is the puller I built to remove the pulley from son's SC. Which would be the same pulley on your SA. HTH
Keith & Shawn(son)
third party image
third party image
third party image
El Toro
09-19-2006 07:21:01
You will need to modifify your puller since your pulley is larger in diameter than the Cub. Hal
El Toro
09-19-2006 07:18:30
Here's the puller that Bigdog made for his Cub.
You can use a hydraulic ram or a jack. Hal
PS: Your local metal shop will make one for around $50.00
http://www.ytmag.com/farmall/messages/459316.html
