Front wheel Shake
Retcol
09-19-2006 14:16:35
I am sure this topic has ben covered a lot but i can't readily find the information. My big Farmalls with narrow fronts all shake when I am on the road. I would like to take them on a tractor ride but I can't stand to put up with the fighting the steering wheel. What do I need to do to fix it?
G Johnson
09-21-2006 18:21:37
 Re: Front wheel Shake in reply to Retcol, 09-19-2006 14:16:35
My H had this problem.To solve it I tightened the castle nut in front of the worm gear in the steering box.Turn the front wheels all the way to the left or right before you tighten the nut.
couv
09-21-2006 10:48:10
On my 100 with wide front end, careful adjustment of toe in took out the shake, finally !
Leee
09-21-2006 04:52:35
The tire pressure is a good idea and make sure the tires match.
JAVP20
09-20-2006 10:36:12
There is also a possibility that the front wheel bearings need tightened up a little. Remove dust covers on front wheels(3 bolts), remove cotter pin, tighten nut until the front wheel won't turn by hand, then back the nut up a little so that the tire will turn by hand. Replace cotter pin and dust cover. Also a possibility that those bearings are about shot and need to be replaced.
mbnok
09-19-2006 17:28:41
I learned this trick from an old neighbor of mine and it sure works for me. He put a shock absorber on the fixture that steered the cultvator. I didn't have that on my 400 so I put in along side and under the frame rail, and hooked it to the front of the bolster above the wheels, it took a little trying to get it to work but I managed and man does it keep the wheels from beating me up while I'm running from pasture to pasture to feed hay.
ih650
09-19-2006 14:57:03
On M's and h's, it's usually the steering bushings for the vertical shaft. Also check the gears. Easy to fix and not too costly.
RAW in IA
09-19-2006 14:31:55
One of my friends who ran Farmall all his life said the easiest way if you don't want to get into a lot of work is to let about 5 lbs. ofair out o f one of the tires in front. Will cause enough drag on that side to keeep it from shaking. Ptherwise, The gears are probably worn, keyway worn, bearings could be loose on steering shaft and can be tightened, and the bolster bearings do wear. Can be fixed, but may cost a bit.
HENRY E NC
09-19-2006 20:48:38
 Re: Front wheel Shake in reply to RAW in IA, 09-19-2006 14:31:55
I drove my 51 M almost 30 miles a couple of weeks ago and by reducing the air by 5 lbs on the left front tire is solved the shaking problem. It works!!!!
