Farma;ll H tires
H fanatic
09-19-2006 17:23:49
Hello,
I have a question about tractor tires for my farmall H. H's origanally came with 11.2 X 38 rear tires, and mine has 12.4 x 38 rears. Is it posible to fit 11.2 x 38 rear tires on the on my rims or not? Thanks Nick
CNKS
09-19-2006 17:35:03
 Re: Farma;ll H tires in reply to H fanatic, 09-19-2006 17:23:49
H's orginally could be had with 9,10,11,or 12-38's, in addition to the early models which had 36 inch rims, along with some special purpose rims and tires. Recommended rim size was usually one inch less that the tire tread width. But, provided you have 10 inch rims, either 10(11.2) or 11(12.4) should work ok. I don't think I would want to put a 10 inch tire on an 11 inch rim, though. MANY H's came from the factory with 11(12.4) inch tires.
DCW
09-19-2006 17:30:30
Yes,a 38 inch tire is a 38 inch tire.I have 12.4'S on the rear of mine,it came with 11.2's originally.I have a buddy using 14.9'S ON HIS.
richard in nz
09-20-2006 01:53:51
 Re: Farma;ll H tires in reply to DCW, 09-19-2006 17:30:30
I have 13.6-38s on mine, it had the original 1944 10-38 Goodyears on when I got it, the 1944 tubes are still in there!
