Air Cleaner
Hurdy in Aussie
09-19-2006 20:40:09
Did the 1950 Super a come out with a glass jar system on top of the oil Bath breather stack.
Incidently i built a rust remover from an 18Gal Plastic drum, with 3 electrodes and Battery Charger i found the instructions for it on your Forum, it sure makes life a lot easier, what a wealth of knowledge you have on your Forum i enjoy loging on each day. Thanks John
Janicholson
09-20-2006 15:56:02
 Re: Air Cleaner in reply to Hurdy in Aussie, 09-19-2006 20:40:09
third party image
I'm trying to post it. JimN
Hurdy in Aussie
09-20-2006 17:48:15
 Re: Air Cleaner in reply to Janicholson, 09-20-2006 15:56:02
G'Day Jim could you explain how you do that
Janicholson
09-20-2006 19:19:50
 Re: Air Cleaner in reply to Hurdy in Aussie, 09-20-2006 17:48:15
Size the picture so it is between 400 and 600kb file size in J peg format. Go to tractor photos(left of screen). Follow the directions there and post the image. when that is finished, it may take several minutes to load, be patient, go to the image (by clicking on tractor photos and selecting yours. Place your cursor on the photo, and right click. Then go to properties at the bottom of this list of options. One of the properties is the U R L of the picture. Use your cursor to highlight the complete u r l and (with a PC) use control C to copy it to your clip board. Then start a new post here (just as you did to start this one). Put in the text and stuff that describes the photo here as well as before. Then select the Optional image U R L box below the comment box and use control V to place the u r l from the clip board in the box. Then submit the message. When it is finished, it will be posted with picture. JimN
Dave Sherburne NY
09-20-2006 19:01:11
 PICTURE POSTING in reply to Hurdy in Aussie, 09-20-2006 17:48:15
Here you go picture posting made easy.
Link
Found this in Kountry Life at the bottom of this page.
JayWalt
09-19-2006 21:49:57
got any pics of your electrolysis device? before and after pics of rusted stuff? just curious as to if its worth it.
Hurdy in Aussie
09-20-2006 02:42:28
 Re: Air Cleaner in reply to JayWalt, 09-19-2006 21:49:57
Have pictures will have to learn how to post them on this site
Hurdy in Aussie
09-20-2006 03:15:33
 Re: Air Cleaner in reply to Hurdy in Aussie, 09-20-2006 02:42:28
third party image
Trying to put pictures in
pat,maplehillfrm
09-20-2006 19:39:45
 Re: Air Cleaner in reply to Hurdy in Aussie, 09-20-2006 03:15:33
here is atry see if it works,
third party image
third party image
third party image
third party image
williamf
09-20-2006 03:48:09
I couldn't get the single pic to show up either.
Does photo bucket limit links to images to make sure people have a chance to see their ads? Or is there a special way to get images posted there to show up here?
Anyway,
