Order Farmall Cub Parts Online
Cub Tractor help
Topgun
09-20-2006 12:23:42
How do I remove the bull gears and lower axle shaft from the final drives of my 1950 Cub? I have removed the housings, but the lower axle shaft will not slide out after removing the covers. Are the axles pressed or what?
emo
09-20-2006 19:41:41
 Re: Cub Tractor help in reply to Topgun, 09-20-2006 12:23:42
i have a 1970 international cub. wher can i find the decals for the hood. i can't seem to find the standard cub decal.
thanks
mike
Bob Underwood
09-20-2006 15:37:39
I purchased a 20T from Harbor Freight still on sale in today's store flyer for 179.00. In my opinion it took most of the 20T.
Bob
Bigdog
09-20-2006 13:14:19
Yes, the axle must be pressed out of the housing.
Topgun
09-20-2006 13:45:18
 Re: Cub Tractor help in reply to Bigdog, 09-20-2006 13:14:19
Thanks for the help Big Dog. Is this something that I can do with a small press or puller? Or do you recommend taking the housing to a machine shop?
What parts are actually press fit? Is it just the bearings?
Thanks again....
Bigdog
09-20-2006 14:00:37
 Re: Cub Tractor help in reply to Topgun, 09-20-2006 13:45:18
The bearing cones are press fit to the axle shaft. If you have a press you can easily do it yourself.
