ih384 valve settings and alt belt
sotxbill
09-20-2006 14:00:12
ok,, just put a head gasket on a nice 384.. can anyone please give me the cold and hot valve settings..
and I goofed up and broke the alternator belt.
how in the world does one change the belt.. the water pump belt has no tensioner?? how does it come off??
thanks in advance.. Bill
sotxbill
09-21-2006 08:32:38
 Re: ih384 valve settings and alt belt in reply to sotxbill, 09-20-2006 14:00:12
great.. thanks for the help... hope I can return the favor some day... Bill
Fromjb2
09-20-2006 18:29:46
Hi Bill, The 384 like the B414 has a split pulley on the water pump.
From B414 operators manual removing the fan belt: to remove the fan belt loosen the set screw in the flange of the water pump pulley and unscrew the flange as far as possible. Start the belt out over the outer flange of the crankshaft pulley and pry out with a light bar or rod. Slowly turn the engine over at the same time the belt will work off the pulley. Withdraw the belt between the Pulley and the fan blades. The belt can now be worked over the fan blades.
Not much room to work in there with the fan guards.
Hope this helps
JB2
mowr
09-20-2006 17:41:44
I only see hot settings: .020 (hot) intake and exhaust.
