M sputters on accelleration. Any ideas??
Read Head
09-20-2006 20:44:40
Hi, I just bought a 1951 Farmall M that runs good at idle and runs good once you get it to high rpms, but spits, sputters and sometimes backfires during acceration. Can anyone help make some suggetions to the problem. Thanks!
Read Head
09-21-2006 15:31:31
 Re: M sputters on accelleration. Any ideas?? in reply to Read Head, 09-20-2006 20:44:40
Thanks Fellas,
I will start with some of these ideas and let you know.
ET
09-21-2006 09:31:44
Spark plugs will cause the problem you describe. try a new set of autolite 388 spark plugs and see if anything changes.
RustyFarmall
09-21-2006 06:55:04
Let me complicate things a bit. Your carburetor may be just fine. The symptoms you describe can also be caused by a weak ignition coil, improper ignition timing(too slow), or leaking intake manifold gaskets. One more thing to consider, these old Farmalls will all exhibit those same symptoms if the engine is not yet warmed up.
jeffcat
09-20-2006 22:58:25
OLD is right there. Also turn the air idle mix screw out a half turn. See if that helps. Other than that you might just end up do the old rebuild bit. Too many things can be wrong with these old toys. Jeffcat
Andy Martin
09-21-2006 05:11:05
 Re: M sputters on accelleration. Any ideas?? in reply to jeffcat, 09-20-2006 22:58:25
How will leaning out the idle circuit help? It should be disabled if the throttle plate is open.
old
09-20-2006 21:14:16
Most likely that the carb is set to lean or the carb/fuel system is clogged up some place. What happens if you choke it when it starts doing that?? If chokeing it helps then your problem is most likely in the fuel system
Read Head
09-21-2006 20:28:10
 Re: M sputters on accelleration. Any ideas?? in reply to old, 09-20-2006 21:14:16
Pulling the choke does help the sputter. I have tried to richen it up, but it does not seem to make a difference. Read
old
09-21-2006 20:44:41
 Re: M sputters on accelleration. Any ideas?? in reply to Read Head, 09-21-2006 20:28:10
Pull the main jet adjusting screww out. You should get a good steady flow of gas when you do. If you don't then your mainjet is clogged up. Also some times you can turn off the gas, then spray carb cleaner in to the main jet and clear things up. Make sure you have the drain plug out when you spray the carb cleaner in so the stuff that has it clogged can fall out the bottom
