mta h
sonoffarmall
09-22-2006 12:22:06
does the MTA use the same sediment bowl as the H?
Andy Martin
09-23-2006 05:55:19
 Re: mta h in reply to sonoffarmall, 09-22-2006 12:22:06
Interesting question. If you have the bowl, try it. If you don't, buy a new one, they are too cheap to put on an old one with hard seals and a warped lip.
They should interchange as Rusty says.
RustyFarmall
09-22-2006 13:56:59
All of the Ms and Hs I have been around used the same sediment bowl.
Janicholson
09-22-2006 13:53:44
To the best of my knowledge, there are Possibly three bowls used. A short bowl that is the same diameter as H/M bowls. The Longer Bowl used on Letter and many number series and others, and a smaller diameter used on some powerplants and stationary gas engines. (this is just from memory, nor a book) JimN
