Fender Installation on H
Pete_5959
09-22-2006 16:05:25
I am installing a set of fenders on my H and am not sure of the proper way to mount with the extension plate and spacers? Do the extension plates mount directly to the axles with the spacers between the fenders and plate? TIA for the directions on this.
Wardner
09-22-2006 22:04:15
 Re: Fender Installation on H in reply to Pete_5959, 09-22-2006 16:05:25
If I am not mistaken, the spacers are used to provide clearance for the drawbar bracket bolts. You use the spacers next to axle housings.
I wonder if the factory or dealers used them on Fast Hitch equipped tractors. There would be no need in that situation.
BEL@IN
09-22-2006 16:36:48
Spacers go between the axle and extension plate, if you use them. I have driven an H 60yrs without them. A little tight but no problem.
