sea foam?
IHnut
09-22-2006 21:07:30
I was told that the sea foam brand of carb cleaner is the best, so I put it in my loboy and BN. While cutting the grass today I noticed that the loboy started to smoke. Is this normal? will it go away after the sea foam is gone?
I havent run the BN yet and if it isn't normal I'm going to drain it out.
Help me I'm scared..
The nut
schertz70
09-23-2006 23:59:17
 Re: sea foam? in reply to IHnut, 09-22-2006 21:07:30
sea foam is great stuff. it will cause your engine to smoke etc because of aal the crap it loosens up. good stuff bor soaking stuck engines and parts. chris
newtothisgame
09-23-2006 19:45:40
yea should clear up we put it in our lawnmowers before winter we use it in everything from truck, tractor, to ice auger only aditive i trust
colekicker
09-23-2006 12:31:42
My fiances 93 infiniti had an electronic injector that quit working off an on. To change it I'd have to remove the intake manifold. Put sea foam in the tank. I have run about 4 cans through it so far. It has made it start running better.
6.99 a can for sea foam.
saving having to pull the intake manifold and a bunch of other electrical crap to replace a $120 injector, priceless.
MAGNUM
09-23-2006 08:03:51
the smoke is from the seafoam cleaning out all the dirt and deposits
Gary -Texas
09-22-2006 23:48:43
We have used sea foam for about a year for every
thing for carbon deposts in our Gas & deisel engines.It has never failed to help ,also getting engines unstuck it is the best! Put it in any type motor,and it will help them. they have some for the transmissons that works to Gary-texas
