C engine will not die
Justin S. - TX
09-23-2006 10:06:54
I recetly converted a C to 12v. I wired it based on Bob Melville's Super M diagram because I am using the distributor from an H or M. Alternator shows good volts, but when I hit the kill switch, she keeps running. I have to pull the coil wire off to stop it. On the diagram it shows a warning light which I do not have, is this my problem? Thanks for any help.
Justin S. - TX
09-25-2006 19:37:17
 Re: C engine will not die in reply to Justin S. - TX, 09-23-2006 10:06:54
Thanks for all your help. Works great.
GA Gave
09-23-2006 18:24:39
I used a JIM-PAK rectifier, part # 1N4004-30. works fine. David.
forklift
09-23-2006 13:27:06
GET A 194 AND HOOK UP FROM A gm RUNNING LIGHT ON JUST ABOUT AND 80S OR EARLY 90 CAR OR TRUCK LICENCE PLATE LIGHTS WORK WELL ALSO JUST CUT THEM LONG ENOUGHT TO WORK WITH IT.
Janicholson
09-23-2006 13:15:54
THe Number is 1N5408 it is a part from an electronics store, not an IH part #. Other diodes will also work, even those from a junk alternator. THe diode must be installed so that current cannot travel toward the ignition from the alternator, just the other way. If you put it in wrong, it harms nothing, but it probably won't charge. JimN
Bob
09-23-2006 18:58:33
 Re: C engine will not die in reply to Janicholson, 09-23-2006 13:15:54
And, here's a picture, so he can get the diode installed the right way, the first time!
Third Party Image
Keith-OR
09-23-2006 10:22:04
Justin, yeppers. You need that warning lite or diode in line. You're getting feed back from the alternator to the ignition system.HTH
Keith & Shawn
Justin S. - TX
09-23-2006 11:58:52
 Re: C engine will not die in reply to Keith-OR, 09-23-2006 10:22:04
Any idea what kind of diode or light? A part number perhaps? Thanks for the help.
russ hamm
09-23-2006 10:14:25
justin, anyway you need to figure this out, because you have constant power to your points and they can get burnt while the tractor is just sitting. does it have the same push/pull switch as an h & m? one lead wire from the starter or solenoid should go to this switch hot and then the other to the distributor. that should be all, but i have not worked on any late tractors, so if it has a key switch then you will have to trace it down. good luck.
Justin S. - TX
09-23-2006 10:21:41
 Re: C engine will not die in reply to russ hamm, 09-23-2006 10:14:25
Yes I have the push/pull switch, and only one wire goes to the coil. Once the motor/alternator stops, there is no juice going to the coil.
