Order Farmall Cub Parts Online
Uncontrolled Cub
John Larch
09-24-2006 08:18:52
My usually reliable Farmall Cub has suddenly developed an issue. While idling along, the engine began to run at extremely high RPM. Now it starts and runs normally for about 5-10 seconds, then revs up to a really scary rate, prompting me to shut down before it blows something up. Is it the governor, and if so how should I proceed to remedy? Any input would be welcome.
John Larch
09-29-2006 07:26:46
 Re: Uncontrolled Cub in reply to John Larch, 09-24-2006 08:18:52
Thanks for all your input. Turns out it was the linkage shaft from the governor to the carb. Always pay to check the simple stuff first, I guess.
Pete in Holland, MI
09-27-2006 07:02:40
On my B a few years ago, the tractor started doing the same thing. Discovered the quadrant on the end of the throttle shaft was loose. Was originally swedged on. A few sharp blows from a prick punch along the gap cured the problem.
Wardner
09-24-2006 13:04:35
Be careful. If reved too high, the cast iron fan bracket can break. You will need a new radiator and front engine cover.
John M
09-24-2006 08:42:56
first check the rod from the cross linkage to the carb. The carter pin may have come out.
