steering part number for an M
Dan Crocker
09-24-2006 15:10:23
Anyone have a part number or picture of the special bolt that prevents the wheels from turning too far left or right? I have a wide front on my M and the bolts have been replaced with regular bolts. On tight right hand turns the wheels will try to lay all the way over.
D Slater
09-25-2006 08:39:05
 Re: steering part number for an M in reply to Dan Crocker, 09-24-2006 15:10:23
Geoff is correct,that bolt wasn't used with wide front. Even if you put it in, the wide front should get to max turn before that bolt would contact stop.
GordoSD
09-25-2006 08:34:12
Make your own by welding a nut on top of a standard bolt and grind/file to shape.
GW
Geoff NY
09-24-2006 15:55:07
There are stops on the wide front that made the long bolt unnecesesary. More than likely the stops are worn and could be built back up with a welder.
Nebraska Cowman
09-24-2006 15:28:06
I'm sure I have one. It's bigger than the one for an H. Email me if you need to.
third party image
Nebraska Kirk
09-24-2006 15:15:16
Here ya go.
48751 DA
