FARMALL H AXLE KEYS
HEYWOOD
09-26-2006 10:16:23
Anyone know the size key that a Farmall H takes where the wheel attaches to the axle? My IH dealer says they list for $60.00 each. Are they special? Thanks
williamf
09-26-2006 16:20:08
 Re: FARMALL H AXLE KEYS in reply to HEYWOOD, 09-26-2006 10:16:23
I thought I remembered dealing with a key when I was putting the wheel back on my H a while back, so I went down to the shed and looked.
Everybody's right.
The axle has two slots 180* apart. The clamp has a key cast as part of it, the wheel has a slot with a piece of 1/2" keystock. I'm guessing that the $60 thing is the clamp, and would try a salvage yard.
Good luck, Wm
Wheelside:
third party image
Clampside:
third party image
D Slater
09-26-2006 13:54:10
What is the cast # on your wheel? If the key they want to sell you is 364699 R1 i may be able to help.
Janicholson
09-26-2006 11:30:30
Cowman is correct (to the best of my knowledge), the key is built in. If it a non standard hub, or if some one repaired one, then it might need a replacement. Measure the slot in the axle for the correct size, then get a replacement from Motion Industries (or= supply store). Make sure it is a little longer than the hub is deep to apply full strength. Good luck, JimN
Nebraska Cowman
09-26-2006 11:10:38
I thought they were cast as part of the hub?
