Super M/MD length
markloff
09-27-2006 05:26:35
Hello,
I know that the Super MD hood is 1 1/2 inches longer than the Super M. Are the frame rails also longer? if not where is the extra length?
Thanks,
Mark
Geoff NY
09-27-2006 16:17:02
 Re: Super M/MD length in reply to markloff, 09-27-2006 05:26:35
Same bolster, yes the frame rails are longer.
D Slater
09-27-2006 17:13:07
 Re: Super M/MD length in reply to Geoff NY, 09-27-2006 16:17:02
Geoff, Frame rails are same length. On MD and SMD the distance from tapped holes on side of bolster where frame rails bolt is different, On the diesel the distance from the holes is longer to the radiator mounting slots and the vertical steering shaft than gas bolster. When they went to bolster like used on SMTA they made bolsters the same for gas and Diesel. Thats why the MTA gas uses same length hood as Diesel.Also same length steering worm shaft as MD.
D Slater
09-27-2006 05:51:11
Front bolster
