Tach disassembly
Mitchissippi
09-27-2006 08:31:07
Any of you folks ever took a 66 series tachometer apart without distroying the chrome ring and the lense? I bought one that looks good, but is reported not to work. I"m gonna try it myself before I dismantle it. I need to replace the lense and the chrome ring on mine. I bought this one for parts.
If it does check out to be bad, I thought I"d cut the tub just behind the chrome ring.
Any suggestions?
Mitch
P Backus
09-27-2006 16:19:04
 Re: Tach disassembly in reply to Mitchissippi, 09-27-2006 08:31:07
I"ve taken them apart by gently going around the back of the chrome ring with a small screwdriver and prying the crimp open. PATIENCE is the key. Just do a little at a time. You may have to go around it a couple of times. There is usually a seal under the glass. You can also re-crimp it again after fixing it by gently going around it with a pliers.
Paul
GordoSD
09-27-2006 14:37:30
I need a lens for the tach on my 966. Are they available somwhere. Or do I have to make my own new (flat) one?
Gordo
Janicholson
09-27-2006 10:22:35
I would use a dremel tool (or =) with a mini cutoff blade in it to remove the bottom of the chrome ring (which grips the body) This allows disassembly. To put it back together I would hot glue the chrome ring in 3 places (with modest amount of glue) then assemble. After placing in the dash I would use Lexcel brand clear acrylic sealer around the chrome to keep water out. Good luck, JimN
Mitchissippi
09-27-2006 10:54:39
 Re: Tach disassembly in reply to Janicholson, 09-27-2006 10:22:35
Thanks Jim! That'd save a good tub.
Mitch
