Hydraulic pumps
Merv
09-27-2006 08:51:25
Hello guys.
I have a question about hydraulic pumps.
I have to replace the pump on my T20.
So I am looking for a belt drive pump. With clockwise rotation.
Any suggestions on pump type and pump size?
The only thing the pump is operating, is the hydraulic blade.
I appreciate any input. You may have.
Merv
Geoff NY
09-27-2006 16:14:51
 Re: Hydraulic pumps in reply to Merv, 09-27-2006 08:51:25
Why not try a power steering pump from a junk yard? Inexpensive and would give you enough juice for your needs. Good luck
merv
09-27-2006 17:36:25
 Re: Hydraulic pumps in reply to Geoff NY, 09-27-2006 16:14:51
I'm not sure a power steering pump will be sufficient. The hydraulic cylinders are 40 inches long. The Rams are 1 1/2 inch. The blade is several hundred pounds.
I have a 20 gallon hydraulic tank. New control valves with float.
Bob
09-27-2006 18:50:13
 Re: Hydraulic pumps in reply to merv, 09-27-2006 17:36:25
A bare minimum of 4 GPM to as high as 12 GPM @ full engine speed is a typical flow range you will want to be in.
Surpluscenter.com has LOTS of pumps, gives some application hints in the catalog, and has tech experts you can talk to on the phone to get application assistance.
A GOOD outfit to deal with.
