cid
Ralph W
09-28-2006 08:25:56
How do you figure out cid if you know the # of cylinders bore and stroke. Thanks
El Toro
09-28-2006 13:20:50
 Re: cid in reply to Ralph W, 09-28-2006 08:25:56
It's r.r.pi.stroke. #of cyl. Hal
PS: r= 1/2 cyl bore
tnlmaverick
09-28-2006 12:38:03
Andy and Randy are both correct because the area of a circle can be calculated using either diameter or radius.
A = pi X (radius)^2
A = pi X (diameter^2)/4
This is true because radius = diameter/2 and
radius^2 = diameter^2/2^2 = diameter^2/4
randy hall
09-28-2006 10:04:29
another way is bore times bore times .7854 times stroke times number of cylinders.
City-Boy McCoy
09-28-2006 09:50:27
Basically, like Tasbrus said:
Radius of bore squared x pi (3.14159) x stroke x number of cylinders = cid.
You cannot use diameter of bore; you must use the radius squared, unless it is a 4" bore. Example: 3" bore. Diameter would be 3". Wrong answer.
Radius squared would be 1.5" x 1.5" = 2.25". Correct answer.
As an example, 3" bore & 4" stroke(Super A): 2.25" x pi (3.14159) x 4" x 4 = 113.08 ci
mike
CNKS
09-28-2006 12:21:25
 Re: cid in reply to City-Boy McCoy, 09-28-2006 09:50:27
I have always done it as tasbras says but if you do the math both Andy and Randy are correct. -- More than one way to do things.
City-Boy McCoy
09-29-2006 03:02:51
 Re: cid in reply to CNKS, 09-28-2006 12:21:25
Exactly. I tried everybody's system; they all work just fine. mike
tasbrus
09-28-2006 09:16:16
never heard it put like that. I"ve always did it
pi(3.14159265) X radius X radius X stroke X number of cylinders.
Andy Martin
09-29-2006 06:11:41
 Re: cid in reply to tasbrus, 09-28-2006 09:16:16
3.14159265358979 That's all I remember.
But 3.14 is plenty close enough to calculate displacement.
But how do you find the radius? Do you measure the diameter and divide by 2? For most folks, it is easier to measure the diameter.
Of course the formulae are the same.
Andy Martin
09-28-2006 08:44:36
Diameter of piston times diameter of piston times 3.14159 divided by four. This is the area of one piston.
Area of piston times stroke times number of pistons.
