B-FARMALL FRONT WHEELS WOBBLE
JR-KY
09-28-2006 11:34:20
What do I need to do to take the wobble out of front wheels or need to look for?It has 2 on the front..
Bus Driver
09-28-2006 14:49:03
 Re: B-FARMALL FRONT WHEELS WOBBLE in reply to JR-KY, 09-28-2006 11:34:20
Those who posted before me have offered good advice. After the things they suggest have been done, check the toe-in on the front wheels.
glennster
09-28-2006 14:38:37
one other thing to check is to be sure the rim is centered on the hub. there is a little wiggle room when you bolt the rim up, and if its off center it will wobble too.
Janicholson
09-28-2006 13:20:42
Four things contribute to the problem. (usually cumulative)
1-There Probably play in the steering Universal joints every little bit makes a difference
2-There is probably play in the worm and sector that are in the fromt casting Sometimes both need replaced. Sometimes they could be repaired (expensive if done well)
3-There could be play in the pedistal shaft that the steering pivots on (Bushing replacement)
4- The wheel bearings could be loose, or worn and loose.
Repairing each of these can be done seperately, I would look for the worst looseness with a friend turning the wheel, and repair that first. JimN
