farmall h logsplitter
handlebar
09-28-2006 20:01:50
i have a farmall h with working hydraulics. Does anyone know if this system has enough power to run a cylinder for a homemade log splitter thanks -jason
Andy Martin
09-29-2006 05:46:49
 Re: farmall h logsplitter in reply to handlebar, 09-28-2006 20:01:50
We made a splitter years ago and went to a PTO powered pump to get speed and oil capacity. Adapted it to an A with a sprocket drive and it worked great.
It's been sitting in a buddy's barn for 15+ years.
old
09-28-2006 21:35:04
Depends a lot on how big the cylinder is that you want to use and if you don't mind takeing you time. The system on an H is low GPM and low preasure so if you use a big cylinder and you don't mind it being slow yes it will work
the tractor vet
09-28-2006 20:28:32
IF the cylinder on the spliter is big enough and ya have enough oil then maybe but keep in mind that if that system is in excelant cond. it only has 950 lbs pressure . So if ya only have a 4 inch cylinder on the spliter NO , most log spliter i have seen need over 1500 lbs or more .
RustyFarmall
09-28-2006 20:27:44
Plenty of power.
