H Tranny won't shift to 5th
ryanfisher
09-29-2006 07:55:20
my h won't shift into 5th gear, and when you do, i hear this godawful grinding noise. have drained tranny fluid and replaced, but still does it. i dont know a lot about these, so if you could walk me step by step in how to repair it and what the problem is, id really appreciate it. ( going down the road in 4th gear ain't too fun)
Bob M
09-29-2006 08:30:57
 Re: H Tranny won't shift to 5th in reply to ryanfisher, 09-29-2006 07:55:20
Does the shift lever move into the 5th gear position OK or does it "hang" close to the neutral gate? If the lever won't move into 5th you need to remove the "5th speed lockout screw" (located on the tranny deck forward and slightly to the left of the shifter tower) and replace it with a standard 3/8-16 x 3/4" cap screw.
Otherwise the problem could be a worn or bent 4-5 shifter fork **or** the 4-5 sliding gear and/or the mating input shaft gear are badly worn. You'll need to remove the tranny cover to determine.
