M Transmission Lube?
Fiddleman
10-04-2006 18:06:47
I want to change the transmission lube in my M. Can someone tell me how much lube to buy or what the capacity of the trans is before I drain out the old stuff? I slowly unscrewed the drain plug to check for water and there was none, just old lube. Also, recommendations on type and brand would be appreciated.
Thanks
Bob M
10-04-2006 18:15:17
 Re: M Transmission Lube? in reply to Fiddleman, 10-04-2006 18:06:47
An M transmission holds about 13 gallons. Make sure you have enough empty buckets ready before you remove that the drain plug!
I've had good luck with 85W-90 gear oil purchased at Autozone, Sam's Club, etc. - whoever has it cheapest. I'm sure this stuff is better quality lubricant than the best available back when your M was built.
