Order Farmall Cub Parts Online
Cub question #12
cubber
10-04-2006 18:45:00
What is the purpose of the drain pipe next to the filter housing? If you drain the crankcase wouldn't most all of the oil drain due to gravity? If not, is this pipe just to get out the remaining few onces of oil? Thanks in advance once more!
cubber
10-05-2006 06:08:37
 Thanks all !! in reply to cubber, 10-04-2006 18:45:00
Yes, it took a wire and lots of scraping to clean it out. Thanks again.
Keith-OR
10-04-2006 22:33:22
 Re: Cub question #12 in reply to cubber, 10-04-2006 18:45:00
It is the oil filter drain pipe....HTH
Keith & Shawn(son)
Jossette
10-04-2006 18:58:28
that might be the crank case breather pipe???
john *.?-!.* cub owner
10-04-2006 18:58:03
There is oil in the bottom of the filter housing, along with dirt, that doesn't drain by remoivng the pan drain. If it hasn't been drained in a while you may have to run a wire up it and then flush the bottom fo the housing out.
