No Start
Gary H1
10-05-2006 15:24:24
I just got my 230 together everything checks out wiring is ok I have spark, gas to the carb rebuilt it to. It will not start. I crank it and choke it gas comes out intake on carb pull the plugs bone dry. Is this a carb problem? Float or what I can't figure this out.
El Toro
10-05-2006 17:14:36
 Re: No Start in reply to Gary H1, 10-05-2006 15:24:24
Your distributor may not be timed to No1 piston.
You need to bring No1 piston to TDC on the compression stroke. Once the piston is at TDC pull the distributor cap and look to see where the
rotor is pointing. It should be at the No1 plug tower, if it isn't pull the distributor and then turn the rotor to the No1 plug tower. Then reinstall the distributor. It's very easy to time it on the wrong stroke. We have all done it.
Hal
old
10-05-2006 17:08:36
You may have the fireing order wrong. Also try this pull the air tube off the carb and hold your hond over the carb. It should suck on you hand pretty good if it doesn't then you have a problem with the valves of a leak in the intake some place
RP-40-9n
10-05-2006 15:36:26
gary , have you checked your carb and manifold gaskets are good and tight? also check that you have compression at the plugs. also could be a bad or sticking float. RP
Gary H1
10-05-2006 16:04:02
 Re: No Start in reply to RP-40-9n, 10-05-2006 15:36:26
Yes this engine just rebuilt. I put in a carb kit from Case IH it had a diferent kind of needle valve. Pin and spring that goes in the middle of needle was not sure how to set it. Like I said everything is tight good spark and wired correctly. I was getting ready to pull carb but wanted to get somebodys opinion first.I thought if you have gas to the carb you get to cylybders when cranking. Thanks for your reply Gary
Jossette
10-05-2006 16:26:09
 Re: No Start in reply to Gary H1, 10-05-2006 16:04:02
I would pull the screw on the very bottom left of carb to see if the float is sticking and that you do not have it in to far...???((**&&^^
Gary H1
10-05-2006 16:39:04
 Re: No Start in reply to Jossette, 10-05-2006 16:26:09
I did gas came out. I just pulled the carb it was full of gas. Why would plugs be bone dry if their is gas in the carb? Should I change float setting?
Jossette
10-05-2006 17:02:40
 Re: No Start in reply to Gary H1, 10-05-2006 16:39:04
with the engine just rebuilt, double check top-dead-center. you could be 180 degrees off.
