F-12 single front wheel date?
Salporin
10-05-2006 15:41:28
Does anyone know the date range for the IHC Farmall F-12 with a single front wheel? I'm figuring 1932 to about 1935 but I want to be sure.
Thanks
BillWK
10-07-2006 05:31:50
 Re: F-12 single front wheel date? in reply to Salporin, 10-05-2006 15:41:28
F12 was built from 1932 to 1938. Single front wheel was available the whole time.
Nebraska Cowman
10-06-2006 03:54:38
The single is listed in the parts book as standard equipment below serial 35340 and special after that.
Farmallgray
10-05-2006 17:55:12
I'd say you have it about right. The single front was standard on the early tractors and then became optional sometime in 1935 or 36 when the double wheels became standard. I could give you an exact date but I'd have to dig through a foot high stack of papers.
CNKS
10-05-2006 17:17:26
F12 was a row crop (cultivating) tractor meaning the single front was available for the entire production run 1932-early 1938.
Werner Von Brauner
10-05-2006 20:23:34
 Re: F-12 single front wheel date? in reply to CNKS, 10-05-2006 17:17:26
Merely because it was a row crop tractor has virtually nothing to do with whether or not such an option was available for the extent of its production run.
CNKS
10-06-2006 06:07:07
 Re: F-12 single front wheel date? in reply to Werner Von Brauner, 10-05-2006 20:23:34
It did on the F series, front ends were interchangeable. I realize that JD and some others had different names for their tractors with different front ends. Many of the F series and letter series were used to cultivate vegetables in narrow rows, for that you either have to have a wide front or a single front wheel. Weird name, are you using as alias because you are afraid to give your real one??
Red Dave
10-05-2006 15:59:25
I would think that a single front wheel was an option for the entire model run.
After all, single fronts were available for the F-14, B, BN, & others too.
