Order Farmall Cub Parts Online
1949 Farmall Cub Charging system????
Retcol
10-05-2006 16:20:15
I was wondering what is wrong with my Cub. I was running it todsy and I noticed that it was discharging, however, when I turned on the lights it would charge slightly. I have never seen this problem before. What do you think is the problem?
Jossette
10-05-2006 17:04:31
 Re: 1949 Farmall Cub Charging system???? in reply to Retcol, 10-05-2006 16:20:15
regulator
Janicholson
10-05-2006 16:51:01
Assuming that it indicates perfectly in the center when off, and that the system has not shown that symptom before, I would say that the voltage regulator (assuming it has one) is getting a bit fuzzy as to where it should set the voltage. It is probably well charged, and when the lights were turned on, it took the load seriously. I would chack the charging voltage when it happens again to see if it is in the 7.2 volt range. JimN
