generator on super a
amo
10-06-2006 06:50:07
does anyone know the make and model number of a 12 volt generatore to go on a 1948 super a, or where you can getr one? thanks for any information
RN
10-06-2006 13:52:57
 Re: generator on super a in reply to amo, 10-06-2006 06:50:07
Small diameter generator? Check for a Ford early 60s-to 64(?) Falcon or Economline van type. If the store carries old foreign parts look for the English Ford generators- same basic generator size. Other possible is adapt VW67-73 generator- they had split pulleys for belt adjustment with their solid mounting- may find archive thread of a H adaption. Rebuild shop can convert 6 to 12 also. Industrial engine shop may have a small diameter Delco available similar to garden tractor starter/gen units. RN.
Nat 2
10-06-2006 07:35:11
Take your generator to an auto parts store, preferably one with an old-timer behind the parts counter. Ask if they can help you find a 12V generator that's similar in size to the 6V one you brought in with you.
The Hitachi 14231 (better verify that) alternator sorta looks like a generator, and provides all the modern conveniences. You couldn't tell the difference at 10 feet.
gene bender
10-06-2006 07:03:53
48 SA was 6v pos ground
HENRY E NC
10-06-2006 07:02:05
I got one for my A from my local Car Quest dealer so most autoparts store will probably have them ,
