The Oil Filter Saga Continues
chad504
10-06-2006 10:16:05
Ok, well I looked at it today. It looks like the outer rim, has been rebuild by weld at some point. Almost invisible until you look into the groove where the gasket sits. It looks deeper there. I"m not sure what to do to fix it, that groove is way too narrow, to try to clean it up with a weld. The old ghasket sealed, but I fumbled with this one for about an hour today, without any luck.
Any ideas? I wondered if I could degreade it with carb cleaner and use permatex gasket stuff in there. It's not too deep, just uneven enough to not seal well.
JayWalt
10-06-2006 20:52:15
 Re: The Oil Filter Saga Continues in reply to chad504, 10-06-2006 10:16:05
My gasket comes off with the can... weird...
Nebraska Cowman
10-06-2006 10:55:55
Yup, I bet some permatex or JB weld would fix it fine. Then never change the gasket again. Once I get a good gasket in the groove, I never change it.
Easy1
10-06-2006 12:52:22
 Re: The Oil Filter Saga Continues in reply to Nebraska Cowman, 10-06-2006 10:55:55
LOL! I thought I was being lazy. I tried to take a gasket out, ended up in pieces, next 10 oil changes haven't touched the damm thing.
chad504
10-06-2006 11:03:06
Ok good, I'll give that a shot tonight. I wish I'd have asked abotu the gasket first. Oh well, now I know.
