Farmall M front pedestal
AOOC
10-07-2006 07:25:46
I have a farmall 44M and 52SM both have a front pedestal. The SM has the older style (heavier cast iron) the M has the newer style more open. I want to switch the tire, center and rims from the m to the SM withiout removing the pedestal itself. The pedestals appear the same. My question is; Will I run into problems switching these wheels and cast centers and are these parts interchangable?
Nebraska Cowman
10-07-2006 08:55:35
 Re: Farmall M front pedestal in reply to AOOC, 10-07-2006 07:25:46
You can switch them if you want but I'd guess they are correct to begin with.
AOOC
10-07-2006 10:06:04
 Re: Farmall M front pedestal in reply to Nebraska Cowman, 10-07-2006 08:55:35
Cowman you are right..they work well the way they are. However, they would be more correct if the heavy cast wheel was on the M and the (newer) cast was on the SM
Nebraska Cowman
10-07-2006 11:59:43
 Re: Farmall M front pedestal in reply to AOOC, 10-07-2006 10:06:04
They would be even more correct on a wide front. But I just looked in the parts book and yes, you are right. Apparently IH discontinued that wheel with the Super M.
