Zenith Carb on 130
EZ
10-07-2006 09:38:13
Removed carb today to service.
On the top is a brass button is a stamped part#?
Looks like an IH number: 366462R91
I did a search on YT but came up empty.
Should there be a main jet needle on this carb?
There is an idle jet. There is a plug in the end where the main should go. Removed that plug and can see a brass insert with a screwdriver slot and a hole in the middle.
I have a main jet from another carb that may work.
EZ
10-07-2006 09:43:27
 Re: Zenith Carb on 130 in reply to EZ, 10-07-2006 09:38:13
Dohh!
Found it! Good match.
EZ
10-07-2006 09:44:23
 Re: Zenith Carb on 130 in reply to EZ, 10-07-2006 09:43:27
Dohh!
http://www.ytmag.com//store/product_files/BK123V_12737.htm
