Framall 400 SM 264 cu engine
VOLfarmall
10-08-2006 05:15:34
I know this is not a pulling sight,But I would like any input into making more power with the 264 cu in engine. With out spenging $10,000 You-all seem to know a lot about these engines I just want to make Good pulling tractor with IH parts if I can I pull in the South and we have some tractor down her SM's that push 175 HP BOred strocked but with the 4 MPH rule I give them a fit with a stock SM , thanks for any help
turbos10
10-08-2006 07:30:41
 Re: Framall 400 SM 264 cu engine in reply to VOLfarmall, 10-08-2006 05:15:34
175HP is not happening with stock RPM and 264 naturally aspirated cubic inches. It would take more RPM and more cubes to do it. It would take 450lb/ft torque at 2000 RPM to make those numbers. The only way to make that power is with around 600-700cid considering the poor VE of those old engines. With more RPM you could make the power with less torque, but they would not be pulling 4MPH.
Moral is someone is blowing smoke up your @#!
D Slater
10-08-2006 07:49:56
 Re: Framall 400 SM 264 cu engine in reply to turbos10, 10-08-2006 07:30:41
Turbos10 Don't know about the horse power numbers. But since a stock C 264 put out close 400 ft. pounds of tourqe, although at low RPM I would think if its stroked and bored as far as some do 450 ft. lbs. of tourqe could be made. He did say in post the ones pushing high horsepower were bored and stroked.
Turbos10
10-09-2006 18:04:50
 Re: Framall 400 SM 264 cu engine in reply to D Slater, 10-08-2006 07:49:56
Sorry, but that is wishful thinking on the part of your information source. At 400ft/lb the M would put out 121HP at the crank. It was closer to half of that. If you want to do the math; (Torque x RPM)/5252 = Horsepower.
The stock M's were less than 50% on volumetric effciency. It would have to be over 100% which is only possible in a finely tuned automotive race engine...or forced induction.
Not trying to argue, but just want you to understand what you can and can not expect from the mighty 264.
Dave in MN
10-08-2006 05:47:45
As long as your TA works, you can be very competative in the 1st gear, slow speed classes. Lose the oil bath air cleaner, shave the stock head 75-100k, put a shorter, stiffer governor spring in, go to the electronic ignition with hot coil, use the 4 1/8 M&W pistons/sleeve upgrade (you don't have to bore block to use).
It will come down to how good a job you do balancing/weighting the tractor, type-tread-cut of tires and how good a job you do driving.
