Kosch Steering Aid, Model B
Tom/Idaho
10-08-2006 10:15:06
I found whats left of a 1944 H today and it has this unit as part of the steering wheel.
Anyone have any information on it? I tried the archives without luck.
Thanks, Tom/Idaho
Nebraska Cowman
10-08-2006 14:16:32
 Re: Kosch Steering Aid, Model B in reply to Tom/Idaho, 10-08-2006 10:15:06
"WHAT IS IT? The Kosch Steering-Aid is a steering wheel with an automatic clutching device built into the hub. It replaces your present steering wheel. Contains no hydraulic or electrical mechanism. WHERE CAN IT BE USED? The Kosch Steering-Aid is manufactured for use on all tractors which are tiresome to hold when driving over rough ground or on side hills.
WHAT DOES IT DO? The Kosch Steering-Aid holds the steering gear stationary, no matter how much 'kick-back' the front wheels get from hitting washouts, ruts or shoulders. The Steering-Aid automatically releases as you turn the wheel so that you can steer the same as always-but without shock!"
Geoff NY
10-08-2006 13:07:02
It"s spelled Koch. We had one on a Ford. Don"t know what"s available now.
