engine swapping
kabiker
10-08-2006 12:41:38
I have a farmall M will a farmall H engine block fit.
Janicholson
10-09-2006 07:47:52
 Re: engine swapping in reply to kabiker, 10-08-2006 12:41:38
Welcome to the forum, The comments below may have good content, but be a bit too lacking in explanation.
The H is approximately the same visual size as an M, they do not have commonality at all. The H is much lighter and less powerful. The effort needed to adapt the engine to the frame, clutch/trans, and radiator is substantial Everything is possible with enough money time and effort. The reaction may have been to the idea of reducing the power from a fourty horse class to a twenty/thirty horse class tractor. Would it work? yes. Would it resell? probably for less than 1/2 of the investment. Finding the 500 bucks plus change to repair the existing engine, or trading the H engine for a rebuildable M engine is the ticket. Jimn
treesandtractors
10-08-2006 20:50:44
Some of us do not have a M to compare to our H or a H to compare to our M. We come to this forum to as questions because we believe that some of you out there will be helpful and give us the information that we need. We have inquistivie minds, we wonder what we can do with what we have to work with. Now for example, I have a Farmall H that I hauled out of a field. The heads were removed prior to its recovery, thus open exposed pistons. Well I thought, I do have a chevy straight six motor out of a 75 Nova, I wonder if I could adapt it over to the H? Or even better yet, what about a V8 350 chevy motor? To all those out there, including Hugh, some of us need to be closer than a 1/4 mile to know one tractor from an other, the good part is, someone out there already knows, and we are not afraid to ask. Try to be helpful, rather than acting all high and mighty. Thank you inadvance.
Don LC
10-08-2006 20:46:53
NOT HARDLY! How about a Briggs?
Chris B.
10-08-2006 15:34:22
No offense, but that would be the sorriest M ever.
Chris B.
DCW
10-08-2006 12:43:03
No,considerable size difference.
kabiker
10-08-2006 12:50:52
 Re: engine swapping in reply to DCW, 10-08-2006 12:43:03
that means block sizes are the same
Nebraksa Kirk
10-08-2006 15:12:12
 Re: engine swapping in reply to kabiker, 10-08-2006 12:50:52
The blocks are NOT the same. The H block is considerably smaller than the M.
Hugh MacKay
10-08-2006 17:24:43
 Re: engine swapping in reply to Nebraksa Kirk, 10-08-2006 15:12:12
Kirk: He's obvoiusly never seen both tractors close up. One should be able to pick out at 1/4 to 1/2 mile.
