IH cab on a 1066
farm boy #2
10-08-2006 19:02:20
I am taking off an IH cab and wanting to know if there is any trick to it. I can see the obvious u bolts to remove along with the front brackets. Is there anything else holding that thing on. How do I hook it for lift off. Any info is appreciated or I will get it off one way or another Thanks
515ryanh
10-08-2006 19:10:49
 Re: IH cab on a 1066 in reply to farm boy #2, 10-08-2006 19:02:20
That is pretty much that it holding the cab on, just make sure you unhook the heater hose and electrical wires and depends on witch cab you have you you need to watch for the batteries. As far as removing the cab you need to lift it straight up. there should be a be a place to put a bolt in at top center on each side to lift the cab up.
