Assie 454 problem
AUSSIE 454
10-08-2006 20:39:49
Gidday from Down under,
I have an international 454 that needs a new or reconditioned/remanufactured bosch fuel injection pump. This is proving to be very difficult to find here in Australia and I was hoping somebody might know where I could find one in the USA or elsewheres. The Bosch Number is EP/VA3/100H 1100CR62. I know there was a BR62 as well, are they interchangable?
Much appreciated,
Aussie 454.
oldtime
10-09-2006 01:25:33
 Re: Assie 454 problem in reply to AUSSIE 454, 10-08-2006 20:39:49
try CoomaDiesal in Canberra talk to dave he has the bits and tons of nos bits
FromJB2
10-08-2006 22:11:56
Hi Aussie 454, what is the problem with the injection pump? Most common problem is leaking front drive shaft seal, causing Diesel fuel to leak into the crankcase. Seal is about $8 CND and CIH stocks them.
JB2
AUSSIE 454
10-08-2006 22:49:01
 Re: Assie 454 problem in reply to FromJB2, 10-08-2006 22:11:56
The tractor would idle but not produce power. The local Case IH dealer took off the fuel injection pump and sent it away. It was returned saying that it was unservicable and I was advised to replace it. That's when I found they were so hard to get in Australia but I was told there were a lot of 454 tractors sold in the USA so here I am.
Hoping I can get the old girl to go again!
Jim Chandler
10-12-2006 19:07:41
 Re: Assie 454 problem in reply to AUSSIE 454, 10-08-2006 22:49:01
I don't know if they have a 454 diesel but a good place to start is Cook's Tractors in Clinton, Missouri. If you would like I'll call around and check for you. I probably can find one if they are around anywhere here in the U.S.
