Carb for a Farmall 100..........................
Patrick Martin
10-10-2006 01:22:51
Hey guys, I still need a carb for my Farmall 100. Does anyone have a good used rebuildable one or a used repro that they would be interested in selling?????
I'm pretty desperate here and need one fairly badly! :)
Nat 2
10-10-2006 05:40:27
 Re: Carb for a Farmall 100........................ in reply to Patrick Martin, 10-10-2006 01:22:51
Have you checked around at tractor salvage yards in your area? A, Super A, 100, 130, and 140 carbs should all work.
Try a wanted ad here.
Try Ebay.
Hugh MacKay
10-10-2006 15:31:59
 Re: Carb for a Farmall 100........................ in reply to Nat 2, 10-10-2006 05:40:27
Nat: According to the parts book A and Super A carbs are different from 100. The 130 and 140 are each the same carb but different from the 100.
A and Super A have a Carter carb. 100 had two different Zenith's during the production run, both with an idle jet only. 130 and 140 supposedly had a Zenith with main jet and idle jet.
I have found a discrepincy in this as my 140 has a Marvel-Schebler carb. The Carter from an A or Super A will not match up to 100, 130 or 140 breather, and if I remember correctly the intake manifold is different size chamber and bolt pattern. I wont be certain on that but believe I remember trying to mount a 130 carb on a SA intake manifold. Didn't fit as I recall.
RustyFarmall
10-10-2006 07:56:07
I have purchased several carbs of the size and model needed from sellers on ebay. Every single one of them turned out to be pretty much total junk. I salvaged a part or two from each of them, and sent the rest to China. A person wants to be very careful when buying carburetors on ebay.
gene bender
10-10-2006 03:00:42
They are listed on this site for 140 go for it. You have a used one now that must not be any good so why take a chance on another one.
Allan In NE
10-10-2006 01:49:19
Hey Pat,
I guess if I needed a carb, I'd order from the "on-line" store at the left side of this page.
They seem to have quite an extensive listing.
Allan
Patrick Martin
10-10-2006 01:55:44
 Re: Carb for a Farmall 100........................ in reply to Allan In NE, 10-10-2006 01:49:19
They do, but I'm attempting to spend less than $200 for one. That's why I sopecified used.
If I have to then I will but I'd like to keep looking till I've exhausted all hope :)
Patrick Martin
10-10-2006 04:15:11
 Re: Carb for a Farmall 100........................ in reply to Patrick Martin, 10-10-2006 01:55:44
@ Gene Bender.
They are but I do not have a core to send in to them. When I bught my tractor it didn't have a carb attached. :-(
gene bender
10-11-2006 16:37:25
 Re: Carb for a Farmall 100........................ in reply to Patrick Martin, 10-10-2006 04:15:11
If you look the rite place a new one does not need a core. Just rebuilts some times want a core.
