road gear on H is shot
Dakotaclassiccycle
10-11-2006 11:02:49
if i hold the stick it will usualy stay in 5th but if i let go it pops right out with a grind. please tell me it is not an expensive fix, dont care bout the labor since wheet is in now and dont need it till spring but dont want it down long either..... ..... ..... .....
GA Dave
10-11-2006 21:09:11
 Re: road gear on H is shot in reply to Dakotaclassiccycle, 10-11-2006 11:02:49
Never, NEVER, drive a tractor to a bar. Nuff said. David.
Andy Martin
10-11-2006 15:23:27
If I remember right you bought an H and resold it for $500 profit at the local bar so you should have the money for the new gears.
Did the one you sold have good gears?
Dakotaclassiccycle
10-11-2006 19:57:13
 Re: road gear on H is shot in reply to Andy Martin, 10-11-2006 15:23:27
better than this ones..... ..... .
but you know, im kinda takin a likin to the rusty ole girl vrses the all red one..... ....
Nebraska Cowman
10-11-2006 11:33:24
not expensive Less tha $300 will buy new aftermarket gears. You can put them in yourself at home.
Dakotaclassiccycle
10-11-2006 11:57:31
 Re: road gear on H is shot in reply to Nebraska Cowman, 10-11-2006 11:33:24
do i gota split the tractor?
Josh in Pa
10-11-2006 12:13:04
 Re: road gear on H is shot in reply to Dakotaclassiccycle, 10-11-2006 11:57:31
Its not hard, but its gonna take some time. You have to remove the cover over the transmission and final drive. (The big cast iron one that the steering column and seat attach to). You have to remove the hydraulic pump, and remove the coupling between the clutch and the input shaft of the transmission. The you can remove the transmission input shaft through the belly of the tractor. After this, the 4th/5th slider gear can be slid off the shaft. I also moved the detent in my shifting rail a little bit (1/16") so that it would really go into 5th gear. Its not hard, but your in for a bit of a job.
Josh
