valve clips
teddy52food
10-13-2006 10:17:51
On a c 113 engine, does anyone know the reason for the horseshoe shaped clips that go on the valve stems?
RR Mech
10-13-2006 21:15:02
 Re: valve clips in reply to teddy52food, 10-13-2006 10:17:51
What is supposed to be there is a small wire hairpin style clip just for safety if the main keepers were to come out or break. It would keep the valve from droping into the engine.
r4etired
10-13-2006 16:59:27
In the event of a broken valve spring the clips prevent the valve from dropping down and a piston hitting it
teddy52food
10-13-2006 14:03:47
They are not the valve keepers. The valve stem has an extra groove below the keeper groove where they fit. I don't see how they would be a seal. They would prevent the valve from dropping on top of the piston if the keepers ever came out.
Janicholson
10-13-2006 13:29:31
Valve Keepers are tapered wedges which (in pairs keep the valve retainer on the stem of the valve. If there is some other horseshoe shaped device, it may be a remaining piece of a valve stem seal of some type. Keepers are real common. JimN
IH2444
10-13-2006 11:57:02
Umm if you are talking about what I think you are, they are to hold the valve in there.
