thermo-sifon cooling system
dennis repaal
10-14-2006 13:24:53
guys- i took your advice and flushed cooling system and it helped alot. now my next question is on my water temp gauge it says cold run hot.there is a white arrow right above the n on run. is that were it should be.that is were it runs now. thank-you. the dumby from wisc. dennis
F-Dean
10-16-2006 08:43:02
 Re: thermo-sifon cooling system in reply to dennis repaal, 10-14-2006 13:24:53
What model are you running? Are you using a thermostat? If you are not using a thermostat on a F-30 or W-30, you need to block off one of the hoses to the thermostat.
dennis repaal
10-16-2006 16:37:15
 Re: thermo-sifon cooling system in reply to F-Dean, 10-16-2006 08:43:02
dean-i have a C and i have not got that far.i flushed the system and it helped i think some.took it for long ride on sat. the temp gauge run on the arrow on temp gauge .the arrow is above the n on run my gauge reads cold run hot. thank-you for your help. dennis
Janicholson
10-14-2006 14:36:41
It is Ideal. Do not worry too much until it gets to the very top of the run range. The thermo-siphon systems have a range of temp based on hotter = more convection. Keep in touch, JimN
dennis repaal
10-15-2006 03:59:57
 Re: thermo-sifon cooling system in reply to Janicholson, 10-14-2006 14:36:41
jim- thank you for all your help.i was in the open modified car racing game for 20 years and you learned real quick not to trust what people tell you. thanks. dennis
RAW in IA
10-14-2006 14:35:42
What model tractor you runing? Dad had a C and it never came up much off the cold area. The guage sender was in the return from radiator to engine, the coldest part of the system.
dennis repaal
10-15-2006 03:52:06
 Re: thermo-sifon cooling system in reply to RAW in IA, 10-14-2006 14:35:42
sir-it is also a c tractor i have.ihave mine plumb to top of head.thank-you for reply. tell me if this is right. dennis
old
10-14-2006 13:55:34
Yep flushing a cooling system can make a world of differance on how hot or cold they run. Sorry can't say for sure on the N your talking about since I don't have a gauge for one any more so I can't look to find out
