Order Farmall Cub Parts Online
52 cub-carb float
RP-40-9n
10-14-2006 19:32:26
can someone help me with setting the float on a 1952 farmall cub? the kit i bought say's 1 and 5- 16 of inch from base to farthest point of float, i set it like that and gas runs strait thru the carband out the breather hole. thanks much RP
old
10-14-2006 19:49:57
 Re: 52 cub-carb float in reply to RP-40-9n, 10-14-2006 19:32:26
May not be the float setting but it could be a bad float or, the needle seat isn't tight or the needle doesn't seat correctly. If it has a rubber tipped needle then it could be a seating problem. Heres the way to fix that. Open up the carb, remove the float and then drop the needle into the seat. Then use a small hammer or punch end etc and tap on it a couple times. What that does is sets the tip to the seat, old trick told to me by a carb guy years ago, but hes long since dead.
Gary Beal
10-14-2006 19:46:54
Hold the carb up level with the float bowl off, attach a small piece of hose to the fuel inlet, blow gently on the hose as you push up on the float. This should give you a good idea where the float is when the fuel actually shuts off. Adjust the float so it is level when the fuel is off.
