pedal adjustment on an h
voager213
10-14-2006 20:13:32
where is there an adjustment to get rid of some of the play on the pedals the brakes need to be pushed down all the way to have any brakes
voager213
10-15-2006 07:02:03
 Re: pedal adjustment on an h in reply to voager213, 10-14-2006 20:13:32
and where do i tighten that does one end turn
kfox
10-15-2006 07:10:19
 Re: pedal adjustment on an h in reply to voager213, 10-15-2006 07:02:03
Loosen the jam nut on the threaded end and turn the clevis. (with the pin removed) :-)
If its old & rusty looking, it's best to remove the whole thing and free it up on the workbench. I have two adjusters off of a H that have the clevis broken off the threaded shaft. They are just stuck on with a kind of spot weld. The adjusters are rare in the boneyards around here, so it must be a fairly common problem. ken
voager213
10-14-2006 20:14:37
thanks for any input just bought the tractor yesterday and dont have the manuals yet
tn terry t
10-14-2006 20:47:29
 Re: pedal adjustment on an h in reply to voager213, 10-14-2006 20:14:37
the only adjustment is located on the arm that comes out of the brake cover its a spring looking out fit with the threaded rod going to a nut made onto the springy thing boy how did you like that techincal description
Nebraska Cowman
10-15-2006 05:40:08
 Re: pedal adjustment on an h in reply to tn terry t, 10-14-2006 20:47:29
This little springy thing
third party image
tn terry t
10-15-2006 16:56:27
 Re: pedal adjustment on an h in reply to Nebraska Cowman, 10-15-2006 05:40:08
yeah thats the springy thing
