300U Tachometer
ksguy
10-15-2006 06:39:41
I'm looking for a new tachometer for my 300U I have found some new reproduction ones but they list a different part number than my book calls for. They say there replaces part number 364 372 R91. Will this replacement work ok ?
TDK
10-15-2006 20:38:29
 Re: 300U Tachometer in reply to ksguy, 10-15-2006 06:39:41
The number you mention is not even in the 300U parts manual. It could be a tach from another tractor that will interchange, but you may have the ground speed problem already mentioned or the mark for the pto rpms may be incorrect. The part numbers in manual are 363829R91 or 365244R91 with IPTO & 364505R91 or 365246R91 without IPTO.
Charlie M
10-15-2006 10:38:51
I just bought a brand new one from Bates for my 300U - haven't had time to install it yet.
CNKS
10-15-2006 07:41:48
I don't know. If it is not the right one, the RPM may be ok, but the ground speeds are likely to be wrong. Bates Corp can repair yours, they have the one off my 460 now. I think they said about $125 plus extra if you want a new face.
