Order Farmall Cub Parts Online
52 cub up-date
rp-40-9n
10-15-2006 19:46:41
i have the cub running great with the new rings and bearrings, thanks to the help of all you guys helping me out. one last problem, im thinking governor- it runs good as long as you throttle up sloooow and easy and it dies a lot when takeing off from standstil, have to slip the clutch to keep from dying. i know very little about trouble shooting the governor. many thanks to a great forrum. RP
Janicholson
10-16-2006 06:15:57
 Re: 52 cub up-date in reply to rp-40-9n, 10-15-2006 19:46:41
I agree with CNKS, the lean condition is the first priority. If it has adjustment screws for High speed/power, open them up one quarter turn at a time till the problem stops, then add an eight turn richer. If there is black smoke, or carbon buildup lean it a bit. If there are no screws, cleaning the carb carefully and setting the float level will fix it. Good luck. JimN
CNKS
10-15-2006 20:08:39
Sounds to me like your carb is too lean. Or your timing could be off (more likely carb related) Check those before the governor.
