W560 rear wheel weights
toolz
10-15-2006 20:47:28
I'm needing some rear wheel weights for my 560 Wheatland. The bolt circle is a lot smaller than regular H/M/560 weights- about 10" between adjacent holes. What tractors used these, besides this one? W9 maybe? Thanks for your help.
toolz
10-16-2006 17:51:54
 Re: W560 rear wheel weights in reply to toolz, 10-15-2006 20:47:28
Thanks, guys. Now I know what to look for. If anyone has any near central IL/IN, I would be interested.
Super 9
10-16-2006 16:06:30
w6 and w560 weights are all by themselves.
Wardner
10-16-2006 18:49:27
 Re: W560 rear wheel weights in reply to Super 9, 10-16-2006 16:06:30
I won't comment on the w-6 weights because I don't know. The w-560 weights go all the way back to the first w-9 and possibly the w-6. Again, the first weight is different from the second weight although I cannot tell you what the difference is.
worm
10-16-2006 06:54:24
W560 rear wheel weights are the same as W-6 rear wheels weights. They will bolt right on, check the parts book.
Wardner
10-16-2006 05:40:22
Assuming that you have cast wheels, the weights are the same for the W-9, SW-9, 600, 650, and International 560. Note that I am not including 660. It's totally different
I-9's and later industrials used the same weight.
The odd thing about these weight is that the parts book says the first weight is different from the second, third and so forth. I have twelve wights on a 650 and they all look the same. No, I am not going to remove five weights and send photos of the weight next to the wheel.
I think I have extra unattached weights that are probably surplus to my needs. I will look at those later today.
Wardner
10-16-2006 06:42:13
 Re: W560 rear wheel weights in reply to Wardner, 10-16-2006 05:40:22
I take back what I said about the industrials. I have one and I can't see how my weights would fit. I thought some of my weights came off another I-9.
Unless, I have another pile of weights somewhere. it doesn't appear that I have any excess W-9 weights. Sorry.
