140 Governor question
E. Ray Heflin
10-16-2006 09:12:20
Hey guys..... .I posted a ? about the governor on a 140 Farmall on 10/9/06. I am helping a friend with his. We order a T&I shop manual (IH-201) and on page 21, the thrust pin appears to be inserted into the housing. The reason I say this is there is only one part shown here. When we took it apart, the pin appeared to be broken. I just got a new one delivered here at work and now I am wondering if it is supposed to be inserted into the housing or just rides againist another pin that is inserted into the housing. We did find a broken surge spring and decided to replace the governor spring and thrust spring while we had it apart. If someone can help us with thrust pin queston, we would be most appreciative..... ...thanks..... ...E. Ray
Bill in oh
10-16-2006 10:06:56
 Re: 140 Governor question in reply to E. Ray Heflin, 10-16-2006 09:12:20
E.Ray Excuse me for not thinking if you are talk about the pin about 3/8 in dia 3/4 or 1in long with a turn down shank it go's in the end of the governor gear in the shaft between the weights.I do'nt think there is any in the front of the housing i was'nt thinking when i discribed the other pin.Bill
Bill in oh
10-16-2006 09:49:13
 Re: 140 Governor question E.Ray Heflin in reply to E. Ray Heflin, 10-16-2006 09:12:20
E.Ray That pin is inserted in the bottom of the housing and go's in the grove in the throttle shaft (bottom). Make sure to check the pin with grove not to low or to high. Bill
