300 questions
texp
10-16-2006 16:59:03
I have a 300 row crop, serial # 1100 s j. What do the "s" and "j" indicate.
Also, I am trying to install a behlen power steering motor. According to a picture in the "IT" manual, it should be mounted with the hoses to the side. There is not enough room between the motor and the valve cover of the engine to mount it that way, can I mount it wih the hoses on top?
Also, where do I plumb in the return (larger diameter) hose from the pump?
Thanks,
Tex
TDK
10-16-2006 20:28:50
 Re: 300 questions in reply to texp, 10-16-2006 16:59:03
"J" means Rockford clutch & "S" means T/A with provision for 540 independent pto.
