Fitting my Tractor?
Kirk in Ks,
10-17-2006 07:43:54
is there a way to move the seat up on a W-6 to make it more comfy to clutch it?
Mine is stock , and my leg is stretched out to just push it in?
Need relief from this<
thought about an M cause it,s shorter to the pedal,s, and shift rod,
John M
10-17-2006 16:14:43
 Re: Fitting my Tractor? in reply to Kirk in Ks,, 10-17-2006 07:43:54
Four bolts at the seat base, take out and move seat foward.Never seen one that couldnt be moved foward before.
JD dozer mike
10-17-2006 15:49:49
lengthen the pedal.
not sure how it is configured.
can you cut it off and weld an extention in ?
if it is cast iron you will need to use nickle AC rods and keep it hot while welding and let cool slow like in sand.
Hugh MacKay
10-17-2006 12:41:31
Kirk: One of the requirements of buying a W6, is you must wear trousers with 36" leg length.
steve from mo - dangit!
10-17-2006 09:06:42
 How short? in reply to Kirk in Ks,, 10-17-2006 07:43:54
Block of wood short, or extension pedal short? There were lots of gadgets over the years to modify tractors.
If you can reach the steering wheel easily, the seat has to stay put. To move the seat, get a couple pieces of steel and make rails to bolt the seat to. Bolt the rails to the platform.
