340D question
VAJerry
10-17-2006 17:18:04
Found a 340D dozer. Just something to play with maybe. Is engine sleeved? If the pump needs a rebuild how expensive? Man says it runs good, I have not heard it, so I'm looking at worse case scenario.
J.J. from Afton
10-17-2006 20:26:14
 Re: 340D question in reply to VAJerry, 10-17-2006 17:18:04
The gas engines are the C135 that were used in the 340 utilitys and rowcrops, which i believe are wet sleeve.
Hugh MacKay
10-17-2006 17:48:39
Jerry: If I remember correctly, it has the same engines as 340 Farmall and Utility tractors. Diesel is a D-166 sleeved engine. I think the gas model was non-sleeved C-153, might have been C-135. The D-166 and D-188 are each 4 cylinder versions of the diesels used in the 460 and 560 tractors, should be good good engines. The D-188 was used in the 504 tractors.
