overheating on a 400
jaybone
10-17-2006 17:19:04
Sequence of events--boilover out of the cap and overflow pipe. Flushed radiator with cleaner then new antifreeze/water at 50/50. Straight water flushed right thru (so radiator not plugged,right?). Ran motor-same thing. Got block tester from local mechanic-no apparent gas in radiator fluid. Also, no antifreeze/water in oil pan or dipstick. So, head gasket ok--right? Level of fluid in radiator at spec level so not overfull and just running over.Hoses ok.Blew out the radiator fins with water and comprssed air--some junk out but seems open to airflow. Any ideas of what to check next? Really puzzled.Thanks
budaa
10-18-2006 10:46:34
 Re: overheating on a 400 in reply to jaybone, 10-17-2006 17:19:04
same thing happend to my 400 right after buying. found that the pully where you tighten the belt for the water pump was loose. there is a set screw to back off and turn the front pully to tighten. hope this helps. dont take much to be loose.
Allan In NE
10-18-2006 06:45:28
Is the gauge reading hot or not? Radiator cap?
Allan
Brian in NY
10-18-2006 06:27:19
Did you flush radiator both ways? From top and bottom?
Jossette
10-17-2006 20:33:15
thermostat
Bob M
10-17-2006 18:25:59
Have you removed the thermostat housing and looked inside? Sounds like the thermostat has come apart and is blocking water flow to the radiator (it's happened to me a couple times...)
old
10-17-2006 17:55:09
I haven't used a auto parts store flush in years, since i have found they don't work all that well. My self I use a vinagar flush. Drain system, fill with 100% vinagar, run tractor till hot, let cool and drain then back flush with water from a hose. All engines that Have do that to so far have since run cool. One or 2 did take doing it twice but it worked
