Farmall 350 carb
Tim Shaw
10-18-2006 06:24:45
I just bought a used replacement carb for my 350. The porous brass plug (not sure exactly what to call it) on the bottom of the carb is mostly missing. Can you get a replacement and if so what is the best way to remove what's left of the old plug and install the new one.
Thanks,
TS
dwag
10-18-2006 10:19:28
 Re: Farmall 350 carb in reply to Tim Shaw, 10-18-2006 06:24:45
Try Dan Clark, (660) 882-5555. Porous plug will let carb air intake drain if needle & seat leak. Some kits will give you a felt plug and retainer. Clark is a "wizzard" on carbs.
Tim Shaw
10-18-2006 10:24:11
 Re: Farmall 350 carb in reply to dwag, 10-18-2006 10:19:28
Thanks for the info. Got to messing around with an old junk M carb that I have. Looks like a welsh plug with a hole in it that held the felt up in there. Plug and felt are long gone in the 350 carb.
D Slater
10-18-2006 11:35:56
 Re: Farmall 350 carb in reply to Tim Shaw, 10-18-2006 10:24:11
When the drain packing and retainer are missing, I get a suitable crankcase breather filter from a auto parts store and a 7/16 inch exspanion plug. Cut what you need from filter material to pack hole. Drill center of plug with same size hole that the M has and use for retainer. Looks like original when finished.
